NEED HELP thiet ke mach BJT
Annie Kitty
New member
chao moi nguoi,
em moi hoc ve dien va that su ko hieu bit nhieu ve van de nay lam nen vao day that su mong nhan duoc su giup do cua moi nguoi
----->>>>topic:
Constant current NiCad battery charger:  NiCad batteries are relatively simple to  charge; for
standard slow charging they  merely require a constant current at C/10 (10% of the rated
capacity) for 14 - 16 hours, most NiCad batteries also support fast charging whereby a constant
current source at C/5 is applied for 7  - 8 hours. Ideally such chargers should also include some
form of electronic control that monitors temperature and cell voltage to prevent overcharging
and/or overheating. For this project, though, you  only need to design a single BJT transistor
based  constant current source  capable of supplying  a fixed current of  ~100 mA to a low
impedance load, independent of supply voltage and load impedance variations (within
reasonable limits).
mong nhan duoc hoi am cua moi nguoi
cam on ve moi su giup do :D
